× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX30 How to increase UDP timeout for Voip
Skymike
I have recently installed RAX30 AX2400 for general use and Voip.  The Voip by Gama is not working correctly and the software supplier advises that the UDP timeout needs to be increased to 300 secs.  I cannot find a relevant setting in the Router and went to Netgear Support who advised ""we do not have an option to increase the UDP timeout".  Can that be correct?  I am not technically proficient enough to know.
Message 1 of 7
Accepted Solutions
microchip8
Master
Re: RAX30 How to increase UDP timeout for Voip
Unless you gain access to the command line of the RAX30 using telnet & co, it is not possible to change UDP or TCP timeouts.
Message 3 of 7
All Replies
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try using the routers DMZ for the VoIP device.
Message 2 of 7
microchip8
Master
Message 3 of 7
Skymike
Firmware is V1.0.10.94_3.  Modem is UK Openreach FTTP ONT, standard UK domestic. VoIP via DECT handsets linked to CISCO ATA192 fed from Router via GS105 switches, cat5e and cat6 cables.
Problem is Game say increase UDP timeout and microchip8 has just messages it can only be dome access to the command line via telnet and that is way outside my payscale.  back to the drawing board, maybe.
Message 4 of 7
Guru
Give the DMZ of the router a try.
Message 5 of 7
Skymike
I appreciate the thought but (a) I am limited by the VoIP software provider; (b) I am not competent to fiddle in the black box ; and (c) I am running a small publishing business here and I am not keen on the potential increased risk in using a DMZ server.  Thanks for taking the time.
Message 6 of 7
Guru
DMZ would only be configured on the NG router. Just as a test to see if it works.
Risk is low for VoIP devices in the DMZ. Not much to hack there.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1566 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
