  • FURRYe38's avatar
    What are you using for wifi scanning?
    Got a screen snip?
    What do the actual devices connected to it show when you pull up their wifi specifics?
    • I am using macbook wireless diagnostics to scan wifi.
      The wifi channel shows channel 149 when macbook connects to the 5GHz wifi.
      • FURRYe38's avatar
