×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Starlink & AX1800 WiFi 6 Router
I cannot get my new AX1800 router to connect to the internet through Starlink. I have plugged and unplugged it all. Still no internet. Any suggestions before I return the router? Thanks for your help.
Message 1 of 10
Accepted Solutions
Re: Starlink & AX1800 WiFi 6 Router
Thanks for your help. I got it to work by bypassing the Starlink Router. LOL - this is not for the inexperienced and faint-hearted! 🙂
Message 7 of 10
All Replies
Guru
What router is it from starlink?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 10
The only one I think that they have (non-business).
Message 3 of 10
Guru
They've got more than 1.
Plus if you're cascading routers, you're in a double nat.
Try putting the netgear in access point mode and then connecting it to the starlink router.
Message 4 of 10
I don't know how to put the netgear router in access point mode...and I can't get in the app - it's stuck on setup mode because of no internet connection.
Message 5 of 10
Guru
Don't use the app. go through the browser setup method.
using the browser you can put it in access point mode
Message 6 of 10
Message 7 of 10
Guru
Either way glad you got it working!
Starlink does make it a bit of challenge as they're wanting to control the whole process.
You might mark it solved so others aren't trying to fix it still.
Message 8 of 10
Ericglanz
How did you end up setting this up? I’m running into the same issue. I’ve set mine up so that the Gen 2 Starlink goes directly into the Ethernet port on the back of the main AX1800 router. When I’m testing speeds I’m only getting about 10mbps of download l, which what my prior speed was so I don’t think it’s working properly. Stand-alone the Starlink router was over 100+
Message 9 of 10
I ended up returning it...nothing I tried would make it work.
I am now using a TP-Link router and it's working fine for what I needed.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2623 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
