× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
VPN passthrough not working
mnhim001
Hi,
I have the Netgear Router RAXE500 and have VPN set up and have been using it since the day I got it.  Just recently, when connected to the VPN, I don't get any Internet or local access pass through.  There isn't much configurations to do on the Netgear VPN setup page.  Does anyone know what's going on?  I am using OpenVPN from my Android phone.
I've changed it from UDP to TCP, and then TCP back to UDP with no luck.
Message 1 of 24
Accepted Solutions
jericonst
Re: VPN passthrough not working
mnhim001,
I reverted back to V1.0.12.96_2.0.45 and the VPN is now working properly...
You might want to give that a try before jumping through a bunch of hoops for Netgear support...
Message 17 of 24
All Replies
Kitsap
Master
@mnhim001 wrote:
Hi,
I am running the VPN server on my R9000.  Attached is a snip from my configuration page.  Your newer RAXE500 will look a little different in the format.
How long has it been since you updated the configuration profile on your phone?
Message 2 of 24
mnhim001
I have updated them yesterday, as well as several times when this started happening.
I do have the same settings selected as you do.
Message 3 of 24
Kitsap
Master
On several Android devices, we are using OpenVPN Connect version 3.3.4.
Not sure where you are connected when you are doing the testing.  You cannot be connected to Wi-Fi that is part of the same network where the OpenVPN Server (on your router) is running.
Message 4 of 24
mnhim001
I tried it using my phones mobile data with wifi turned off. I also tried it at work, using my works wifi.
Message 5 of 24
Kitsap
Master
With your VPN connection established, on another device on your LAN, can you log in to your RAXE500 and see your phone as a connected device?
Have you checked the connection logs generated by the OpenVPN Connect application?
Do you use a service like No-IP for Dynamic Domain Name Server?
Message 6 of 24
mnhim001
I was able to view the log and I see the GW and DNS as 192.168.254.1. This is not the local IP of my router. I had reassigned it when I first received the RAXE500. Can this be the issue? If so, how do I even change it within the router?
With VPN connected, it does show on my RAX500 that I am connected. I was able to check RAXE500 on a LAN connected workstation.
For testing, I used my mobile data to connect to VPN, then tried to access the RAXE500 admin page and it failed. After disconnecting from VPN, tried the admin page again and it worked via the same device.
I am using the DDNS option built into RAXE500 which is hosted by No-IP. It's a turn on or turn off function, nothing to configure on that page.
Message 7 of 24
Kitsap
Master
I presume you have a valid login at No-IP and pay their annual fee?
What device, brand name and model number, is upstream of your RAXE500 between it and the internet?
Message 8 of 24
mnhim001
I am only using the no-ip free account.  So, I log in monthly to keep the name alive.
I have fiber with hardware provided by Frontier.  I don't have that information with me at the moment.
Message 9 of 24
jericonst
I am having the same issue and have been working with Netgear support for a while on this. They are unable to find a fix for the issue so far. Maybe a firmware update is needed to get this fixed?
Message 10 of 24
mnhim001
What is the issue that they have given to you?
Message 11 of 24
Kitsap
Master
@mnhim001
Repeat question: What device, brand name and model number, is upstream of your RAXE500 between it and the internet?
Message 12 of 24
jericonst
Hi mnhim001, Netgear support spent almost 2 hours trying to fix my issue before I had to leave the phone call... They took my phone number and said that they would call back and I haven't heard from them yet.
Also, I am discussing the problem with Netgear support over email. No resolution there either.
I did find this: https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/RAXE500-VPN-missing-client-key/m-p/234...
I think I may try to revert to the older firmware today to see if the latest firmware is the cause of the broken VPN. It would be nice to hear from Netgear support on this sooner than later...
Message 13 of 24
jericonst
All the information is in my ticket # 47957947... Please review the ticket...
Message 14 of 24
Kitsap
Master
@mnhim001
It is easy enough to confirm if the client.key configuration file generated by your RAXE500 is empty or not.
Do a fresh download of the Windows configuration zip file from your router.  Extract the client.key file from the zip file.  Use a text editor program like Notepad to open the file and look.  The file should be several lines of encrypted data.
See attached.  Report back your results please.
Message 15 of 24
mnhim001
It does show private key, but does not show as an RSA private key.
Message 16 of 24
jericonst
mnhim001,
Message 17 of 24
Kitsap
Master
@jericonst wrote:
mnhim001,
@mnhim001
You do not have the same issue as @jericonst.  However, his information was informative.
Back to the question, what device brand name and model number is upstream of your RAXE500?  Configuration of that device can block the RAXE500 from having access to the internet via OpenVPN.
For test purposes, you might want to revert back to the firmware version noted above.  If you do, be sure and turn off automatic firmware updates.  Also you should create a new set of configuration files with the old firmware.
Message 18 of 24
mnhim001
I think its an issue with port forwarding.  I opened up a port trying to setup WireGuard and that still didn't work.
I went to https://www.yougetsignal.com/tools/open-ports/ to check if my port was open and it shows closed.
Again...sorry I forgot to gather the information you needed on my Fiber hardware.
Message 19 of 24
mnhim001
@Kitsap
Reverting back to the previous firmware worked.  Thank you for helping me troubleshoot.
@jericonst
Thank you for your suggestion, it worked.
Message 20 of 24
c4rloco
Tutor
I am also experiencing the same issue (VPN Passthrough is not working). I can connect with errors to the VPN but I cannot browse any website.
I opened the case# 48002888 in case this helps.
Message 21 of 24
mnhim001
Go back 1 firmware.
Message 22 of 24
c4rloco
Tutor
Absolutely. That was the only way to get the VPN Passthrough working. Going back to V1.0.12.96_2.0.45
NG needs to definitely do a better job with these releases.
Message 23 of 24
Guru
Message 24 of 24
Top Contributors
Discussion stats
  • 23 replies
  • 6708 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
