- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What's the current status of RAX120 in 2023?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thinking of buying "Netgear Nighthawk AX12", mainly use as AP. But I read lots of bad review regarding rebooting problem. What's the current status on this? solid enough after firmware upgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What's the current status of RAX120 in 2023?
so you'll see a lot of reports from them on here as this is the forum where people come with issues.
So you'll see it a lot of here.
but if you're looking for mainly an access point, why not just get an access point?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RAX120 is a waste for using it just as an Access Point. If you need that, just get an Access Point instead of a full-blown high-end router. It's overkill to get the RAX120 and use it as a simple AP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you really want the RAX120v2 then there is a patch that fixes the random reboot issues seen only on v2s.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans @microchip8 For $200 range, you really can't get a good AP at this price. WAX615 only rated for AX3000 but weak cpu and memory.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, but you get more for about same money, better cpu, better memory and antenna than pure AP device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you can get it for that price and its cheaper than the equivalent AP, I'd give it a shot.
Yes, you do see some reports but there's many users that have zero issues. You just don't see them posting on here.
Plus you'd have a pretty solid backup router if something ever did happen to your primary router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And issues with the RAX120 reported here are unlikely to be for devices in AP mode.
They usually deal with features that are disabled in AP mode.
Fortunately, that does not include USB access with ReadySHARE. That still works with routers in AP mode.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
