Orbi WiFi 7 RBE973
Reply
Orbi RBR 750 does not connect to Epson Workforce 545 Printer
Pablo1601
I've made several attempts to connect my Epson Workforce 545 to my Orbi network but cannot connect.  Is there a way I can connect?
Message 1 of 16
Accepted Solutions
Steve1Ski
Initiate
Re: Orbi RBR 750 does not connect to Epson Workforce 545 Printer
Thanks for the advice Mikey94025.
.My Epson Artisan 837 connected right up (Orbi RBR 750 ) once I followed this step:
  1. Set CTS/RTS threshold for 2.4Ghz to 2347 in Advanced... Advanced... Wireless Settings.
Best regards,
Steve1Ski
Message 12 of 16
All Replies
CrimpOn
Guru
It is sort of awkward now that people are buying the new "AX" Orbi's to point out that Netgear has a community forum specifically for those products: https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Searching for "orbi forum" brings you here, where we all have the "original Orbi".  Besides the obvious envy, we have no experience with the AX products.  You will probably get much better advice by posting in that forum.
Because connecting printers should be very similar no matter which Orbi is involved, can you describe at what point in the process "things break down?"  Looking at "Connection Options" in the installation guide, where does it fail?
https://files.support.epson.com/pdf/wf545_/wf545_bb.pdf
Message 2 of 16
Guru
Any progress on this?
Message 3 of 16
ak45
I'm having same problem, RBR750 orbi wifi is not connecting to Epson Workforce 635 Printer. I have tried changing the channel for 2.4 Ghz from Auto to 11 and 6, but still printer is not connecting to wifi. Tried WPS push button method as well as manual, nothing is working. Please let me know if anyone knows hor to fix this issue. Printer was working fine on old router.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 4 of 16
Guru
Try disabling AX mode on 2.4Ghz.
Try setting CTS values from 64 to 2347, Under Advanced Tab/Advanced Settings/Wireless Settings...
Message 5 of 16
Mikey94025
Hero
Try each of these (in order):
  2. Turn of AX mode for 2.4Ghz in Advanced... Setup... Wireless Setup.
  3. Try changing your wireless security to "WPA-PSK [TKIP] + WPA2-PSK [AES]" in Advanced... Setup... Wireless Setup.
    • If this works, this is not an ideal workaround because you are degrading the security of all your wireless devices just to support a 10-year-old wireless printer.  Now may be a good time to upgrade your old printer to one that supports the latest and most secure wireless protocols.
    • Do you recall what security setting your old router was using? It may not have been WPA2-AES but instead "WPA2-PSK (TKIP)".
Message 6 of 16
Pablo1601
All,
Thanks for the recommendations and posts regarding my problem with Epson Workforce 545.  I initially had a conflict with my AT&T modem and ORBI 750 router that precluded my printer from printing and scanning.  The conflict occurred because my printer was using an AT&T generated address provided by the modem.  I corrected the problem by resetting my printer and applying an ORBI generated address.  Thanks much.
Message 7 of 16
Guru
Glald you got it working.
Regarding modems with built in routers, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
@Pablo1601 wrote:
All,
Message 8 of 16
skeelo
Luminary
As someone that previously dealt with a double NAT, I recommend option two if possible.  It should be the easiest of the three options to execute and retains all of the features of the Orbi instead of being reliant on/ limited to the feature set of your ISP's modem.
I was able to set up option two without any contact with my ISP.  The modem's config capabilities were fairly straight forward once logged in and I had DMZ setup with the Orbi outside and the wireless radios off after a few button clicks.
Good luck.
Message 9 of 16
ak45
Thanks a lot, it worked with the changes you recomended!
Message 10 of 16
Guru
Please mark your thread as solved so others will know. Enjoy. Smiley Wink
Message 11 of 16
Steve1Ski
Initiate
Best regards,
Steve1Ski
Message 12 of 16
Pablo1601
Message 13 of 16
Guru
Glad it worked. Enjoy. Smiley Wink
Best regards,
Steve1Ski
Message 14 of 16
AWinLA
Thanks for this.  Worked perfectly for me on both my printers (Epson & HP).  I'm a DIYer on home tech but clearly I was in over my head on this issue.  Great to have help.
Message 15 of 16
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 5886 views
  • 5 kudos
  • 8 in conversation
Announcements
Orbi WiFi 7
