OldBullOne's avatar
OldBullOne
Orbi RBR850 into insight
Does anybody know if I can add this router into insight?
Insight shows it, tells me to use a code (which it shows me) and go to the routers webpage...but I can't figure out what to do there...
  • FURRYe38's avatar
    Have you tried using the Enter Serieal Number option at the bottom of the Insight app? You would look at the serial number at the bottom of the RBR...
    • OldBullOne's avatar
      OldBullOne
      Tnx, tried that, as well as scanning the code...but insight won't let the Orbi in...I guess the attached photo shows the state of things.
      Which is strange...why?
      • FURRYe38's avatar
        Seems like Orbi AX is not supported by the app. :smileyfrustrated:
