Orbi WiFi 7 RBE973
Reply
Can the Orbi Pro and Orbi RBW30 Satellite work together?
emaniat
Can the Orbi Pro work with the RBW30 satellite?
Thanks.
Model: Orbi Pro Tri-band WiFi System (SRK60) AC3000
Message 1 of 3
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: Can the Orbi Pro and Orbi RBW30 Satellite work together?
Hi emaniat,
RBW30 only works with Orbi Router RBR40 or RBR50. Orbi Pro SRK60 works with an add-on satellite SRS60.
Here is the datasheet of RBW30.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 2 of 3
All Replies
JohnC_V
NETGEAR Moderator
Hi emaniat,
Message 2 of 3
emaniat
Thanks for the info.  Still new here and getting my feet wet.   Will definitely use Accepted Solution when my questions are answered.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3141 views
  • 1 kudo
  • 2 in conversation
Announcements
