ry8s's avatar
ry8s
Netgear Orbi SXR30 4.3.4.200 Killed 1 Wifi Network?
Hey all,
After the latest firmware update on my Netgear Orbi SXR30 Router and its 2 SXS30 satellite APs a month ago - my main wifi network has been basically disconnected. Tablets, laptops, Matter IoT devices, Roku TVs - either they can't connect to the network at all, or they 'connect' but have no internet access, but I think they do have LAN access.
At first I thought it was a messed up Satellite as it looked like it got un-synced during the update (magenta light) so I unplugged the satellite, and issues persisted. I killed & re-synced the Satellite and things magically started working for about 8 hours and then all of a sudden network issues came back. Once again it just started working on its own, phones, tablets, everything on wifi could all of a sudden connect. That lasted for a few weeks, but the last few days, once again, everything has gone to hell, until late last night, and as of right now, everything is working just fine. I did re-apply the new firmware update yesterday since downgrading didn't seem to do anything.
A list of items I've noted so far:
  • This only impacts wireless devices on a single VLAN (1)/ wifi network (also 1 with that VLAN applied).
  • Hardwired devices on the same VLAN (PC, Servers, RPi) have thankfully had no issues.
  • I tested with a laptop - on wifi it can't connect, plug into a satellite and it can connect fine - all the same VLAN.
  • I do have multiple VLANs and it does appear to only be this 1 VLAN that of course is my main network. it looks like everything on my IoT network continues to contact the internet just fine.
  • I gave my iPhone a static IP, and it shows up in my Netgear Orbi portal but my phone will not use the wifi for internet access but can access the local network.
  • Some other devices can't access the network at all. I don't see any IP Conflicts or anything else digging around the admin portal and nothing in the logs.
Please let me know if anyone has ANY idea or trail I can track to see what is going on here. Much appreciated!
  • FURRYe38's avatar
    So this happens will all other wireless VLANs disabled?
    Did this happen on prior version of FW?
    How was the FW on the system updated? Manually or automatic?
    Has a factory reset and setup from scratch been performed since updating to check this problem?
    • ry8s's avatar
      ry8s
      I have not tried disabling any other VLANs or other wireless networks - I will test that the next time the issue occurs.  The issue disappeared a couple days ago, last time it took a couple weeks for it to come back, and then also resolved after a couple days.
      This did not happen on any previous FW - except the issue did persist after downgrading to 4.3.3.106.  All upgrades to 4.3.4.200 have been through me triggering it though the Netgear Insight iOS app.
      I have not done a factory reset yet, that will likely be my next step if the issues comes back.
ProSupport for Business
