Networksniffer
Oct 06, 2020Guide
Orbi App
Hi,
After a update of the app I thought everything worked out fine but the orbi App just hangs again. I tried mij IPad en IPhone to connect the AC3000 SSR60 with the orbi app, no way. Checked the the local Network lever alle settings are correct. Re-installed the app again but it want matter. So is there someone that have a new clue. Gif me a hint. Thanks.
Networksniffer wrote:
After a update of the app I thought everything worked out fine but the orbi App just hangs again. I tried mij IPad en IPhone to connect the AC3000 SSR60 with the orbi app, no way. Checked the the local Network lever alle settings are correct.The Orbi App is not intended to manage Orbi Pro or Orbi Pro AX. Use the Insight App instead.
1 Reply
