Orbi WiFi 7 RBE973
Reply
Orbi pro (SXK80) behind UDM router | Dynamic Vlan via radius
Filis
Dear community, dear Netgear Team,
I set up a UniFi UDM as a router with a radius server. Behind the UDM, I am running a Orbi Pro (SXK80 and a SXS80) on firmware 3.3.0.122 as an AP. The challenge is that I would like to dynamically assign a vlan to Orbi clients based on the radius authentication on the UDM.
For now, the authentication works, but the ips assigned to clients do not match the correct vlan address range, even though the tcpdump on the UDM indicates the right vlan in the accept message. so it seems the Orbi pro just doesn’t “understand” / “convert” / “translate” the radius reply correctly to its clients.
I found some documentation on dynamic vlan for other netgear products but non of it for the Orbi Pro. The configurations mentioned for other products (dynamic vlan, …) are not available in the Orbi pro Settings, so I cannot select anything but the radius ip, port and shared key.
If I select a vlan, only the selected address range is used, even if the radius credentials and the tcpdump would suggest a different address range.
How can I configure the Orbi Pro to dynamically select a vlan?
Thanks
Message 1 of 7
Filis
Betreff: Orbi pro (SXK80) behind UDM router | Dynamic Vlan via radius
The tcpdump
21:46:58.681381 IP (tos 0x0, ttl 64, id 53332, offset 0, flags [none], proto UDP (17), length 221)
[ip address router].1812 > [ip address SXK80].44930: [udp sum ok] RADIUS, length: 193
Access-Accept (2), id: 0x17, Authenticator: [mac address]
Acct-Interim-Interval Attribute (85), length: 6, Value: 01:00:00 hours
0x0000: 0000 0e10
Tunnel-Type Attribute (64), length: 6, Value: Tag[Unused] VLAN
0x0000: 0000 000d
Tunnel-Medium-Type Attribute (65), length: 6, Value: Tag[Unused] 802
0x0000: 0000 0006
Tunnel-Private-Group-ID Attribute (81), length: 4, Value: 30
0x0000: 3330
User-Name Attribute (1), length: 11, Value: users
0x0000: [digits]
Vendor-Specific Attribute (26), length: 58, Value: Vendor: Microsoft (311)
Vendor Attribute: 17, Length: 50, Value: ..&...P...I..o.nd.^e.U...k1.d.[an..@lQ.........C..
0x0000: [8 blocks of 4 digits]
0x0010: [8 blocks of 4 digits]
0x0020: [8 blocks of 4 digits]
0x0030: [4 blocks of 4 digits]
Message 2 of 7
schumaku
Guru
Not aware the Orbi Pro AX has this feature on board.
@BruceGuo please.
Message 3 of 7
Filis
Thank you, @schumaku.
@BruceGuo
I was hoping there is an option to do something like this with the UDM as a router and OrbiPro (SKX80) as a wifi access point?
https://www.downloads.netgear.com/files/answers/Dynamic%20VLAN%20Assignment%20using%20RADIUS.pdf
https://www.youtube.com/watch?v=l2ivHDIV50g
https://www.youtube.com/watch?v=AJcKsGtyfHo
Message 4 of 7
BruceGuo
NETGEAR Expert
Thanks for sharing your opinion. I know the feature. I will check with internal teams if we can do it and what's the plan.
Message 5 of 7
Filis
Hi,
do you have any update?
Thank you!
Message 6 of 7
BruceGuo
NETGEAR Expert
Hi
We have been discussing the feasibility of impementing in Orbi Pro mesh system. We still don't have the anwser yet. We will keep your post.
Bruce
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1567 views
  • 2 kudos
  • 3 in conversation
Announcements
