shibbard's avatar
Sep 19, 2021
Prepurchase question - Orbi Pro setup on existing network
I would like to set up a mesh wifi connected to our existing office & light manufacturing network.  Our current system is:
two fiber ISPs connect to:
1 -  microtik router which splits off VOIP to phone system and data to Meraki firewall
2 -  directly to Meriki firewall
Meraki firewall functions as router, DHCP server and of course firewall.  Also failover between the two fiber sources.
from firewall, data goes through HP managed switch to wired network.
Can I set up an Orbi system connected to this network to create mesh wifi behind the firewall?  I tried with another maker's home system and was unable to complete a setup that would work using the admin interface it provided so I want to confirm I can do this prior to making another purchase?
Thanks!
  • plemans's avatar
    You should be able to.
    I've ran my SXK30 in access point mode attached to my current network.
    And it worked fine.
    I say *should* because stranger things have happened than a firewall/other router caused issues.
    • shibbard's avatar
      shibbard
      Tutor
      plemans Thanks for your response -
      Sorry to ask an obvious question but did your SXK30 function as a primary or parent node with child nodes on a mesh network when set as AP?
      • plemans's avatar
        Not sure exactly what you mean by "parent" "child" nodes.
        I've ran it in AP mode connected to the following: arris w31, Orbi RBK53, and a CAX80.
        Just to test them.
        I had the SXR hardwired in and then the SXS both hardwired and wireless (to test).
ProSupport for Business
