BMiglionico's avatar
BMiglionico
SXK50 Wifi 6 Pro Mesh Newbie Question here. Can I use this with the SXK80 Wifi Pro Mesh System?
  • I have 3 of the SXK80 (2 routers and 1 point) and 2 of the SXK50 (1 router and 1 point). My thought was to use 1 SXK80 as router, and bridge the other SXK80 router, as well as bridge the SXK50 router to more or less have 1 Main router and 4 points...?
    Would I be correct in my thinking/process?
    • JeraldM's avatar
      JeraldM
      NETGEAR Employee Retired
      BMiglionico,
      Welcome to the community!
      It is possible to have just one SXR80 function as a router as long as the others are running in AP mode; however, there could be difficulty with setting up the satellites in which you'd usually have to perform a factory defaults and sync them if you're going to connect them wirelessly.
      Ideally, an Orbi Pro network consists of just one router and multiple satellites in which the maximum is 6 (please check this KB article for your reference).
      JeraldM
      NETGEAR Community Team
ProSupport for Business
