beansontoast's avatar
beansontoast
BUG: Orbi no longer using port forwarding after restarting - but settings still listed correctly
Hello!
As in  description, this is reproducible for me 100% of the time when doing the following:
- set up an entry in port forwarding
- check it works (it does!)
- power down your Orbi router*
- switch it back on*
- wait a bit for everything to be back and ready
- check port forwarding - no longer working! (can wait a few more hours and try again - never comes back!)
- go in to settings, notice port forwarding setting is still listed correctly - so should be working...
- delete the port forwarding setting, re-add setting - works again!
*any kind of restart of the router, could be a normal restart or a power off/on.
It seems that port forwarding stops functioning if the  router is restarted. - however the setting is still listed, so the setting is not lost - it just stops working. The only way I can get it to work again after a restart is to remove the setting and re-add it exactly as it was. The local machine it is pointing to has not changed IP address.
This is on firmware   V4.4.1.29_3.10.80, but was also present on previous firmware I was using.
Cheers,
