- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Carrier Infinity Touch Thermostat won't connect to Orbi RBK852 (AX6000) WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just replaced my Orbi RBK50 system with a new WiFi 6 Orbi RBK852 (AX6000) mesh system at my home. I kept the same WiFi network SSID and password from the RBK50 and all of my devices successfully attached to my new RBK852 system. All but one device: Carrier Infinity Touch Thermostat (Model SYSTXCCITC01-A).
This is an older smart thermostat that's been installed at my home for just over four years. I had no problems connecting the thermostat wirelessly to my old Orbi RBK50 system over the past year, but it would not connect to the RBK852.
After much online searching, I found a posting on the Netgear Community: How do I connect my PlayStation 4 to my Orbi WiFi 6 System?
This worked for me! Summary: change the CTS/RTS Threshold values to 2347 for both the 2.4GHz and 5GHz wireless settings.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, NG is defaulting to 64 on there Orbi AX system which for some older devices or some Iot, doesn't work well so setting 2347 is a alternative solution. Glad you got it working. Please mark your thread as solved so others will know.
Enjoy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Carrier Infinity Touch Thermostat won't connect to Orbi RBS750 (AX4200) WiFi
Hi,
I saw the thread about Carrier Infinity Touch not able to connect to AX6000. I have the same problem but with AX4200 (RBS750)
The solution provided is - "change the CTS/RTS Threshold values to 2347 for both the 2.4GHz and 5GHz wireless settings."
How to do this? I am a non-tech person.. can someone please send the details (steps) please?
Thanks
Arch
- Mark as New
- Bookmark
- Subscribe
- Permalink
Use a wired PC and web browser and navigate to 192.168.1.1 or orbilogin.com.
Under Advanced Tab/Advanced Settings/Wireless Settings to change CTS values.
@Arch666 wrote:Hi,
Thanks
Arch
- Mark as New
- Bookmark
- Subscribe
- Permalink
I followed th instructions.. thanks FURRYe38 (Guru) 🙂
My thermostat is connected to Orbi's network
- Mark as New
- Bookmark
- Subscribe
- Permalink
