bowler304's avatar
Jan 31, 2023
Carrier Thermostat systxccitc01-b can't connect to Orbi AX6000 RBR850 / RBS8540
Hello,
I have a carrier thermostat systxccitc01-b and it suddenly won't connect to my Orbi Router.  The strange thing is it worked fine for almost a year.  I found another thread to change the following CTS/RTS Threshold to 2347 and that didn't fix it.  I turned off the AX for 2.4GHz and that didn't fix it.
RBR850 / RBS850 Firmware Version 4.6.14.3
I'm open to options, as I would love to have this connected to a wifi network.  I can turn my phone on and use the same passphrase and it works fine.  So the passphrase is not too long.
Firmware is up to date.  Let me know if you got solutions.
  • bowler304 wrote:
    Hello,
    Make sure you tried a full reset of the networking on the thermostat (like "forget network") and then pair again to your Orbi wifi SSID.
    • bowler304's avatar
      bowler304
      Tutor
      "Make sure you tried a full reset of the networking on the thermostat (like "forget network") and then pair again to your Orbi wifi SSID."
      I have done forget and set up 3 or 4 times now.  It will connect but won't talk with their servers, but when I bring up my router settings it doesn't show the device is connected to the internet.
      • plemans's avatar
        So its connecting to the wifi?
        Just not back to their server?
        What modem/gateway is the router connected to?
        Are you using Armor?
  • CrimpOn's avatar
    CrimpOn
    bowler304 wrote:
    Hello,
    If the thermostat "worked fine" for almost a year, then there should be no reason to modify the router settings.  If it worked for a year, it should still work.
    How did this situation come to your attention?
    What happens when you go through the setup steps on page 58 of the user manual?
    https://www.shareddocs.com/hvac/docs/1009/Public/0C/OMSYSTXCCITC-08.pdf
