- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Devices connected to Satellite RBS850 loses WLAN connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
have a RBS850 in the attic. This is connected by wire to the LAN. Since I moved the RBR850 router to a different location in the basement, the devices connected to the RBS850 keep losing the wireless connection and then connecting to the RBR850.
My assumption is that the RBS850 connects to the RBR850 via WLAN and thus the problem occurs.
Affected by the problem are Windows PC and Apple devices.
Both have the latest firmware: v4.6.8.5_2.1.9
The whole network is based on netgear components
Does anyone know the problem? Thanks for the support.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think the problem is solved. I have not experienced another wifi outage since 24 hrs. I have deactivated the RBS850 again and reactivated it after about an hour. During the activation I pressed the reset button. In difference I used a paper clip and not the wire which I had used before. I was clearly paying attention to whether the button was responding or not. It takes about 20 minutes until the RBS850 was back online. I thank everyone for the support. If I do not contact you again the problem is solved.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Devices connected to Satellite RBS850 loses WLAN connection
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The service provider cannot have any influence on the problem, if I am connected to the same switch as the RBS850 via LAN wire, I have a communication without interruption.
What is the size of your home? Sq Ft?: Basement floor - 1 and roof floor floor 3
What is the distance between the router and satellite(s)?: There is only one satellite and it is on the 3rd floor. That is about 7 - 10 meters. And as mentioned before, the RBS850 is also directly attached to the LAN by wire.
What channels are you using?: I use the defaults for the WLAN settings.
Any Wifi Neighbors near by? If so, how many?: We live in a housing estate and there are various WLANs in the area. Actually I see between 7 other WLANS
- Mark as New
- Bookmark
- Subscribe
- Permalink
This RBS850 remains connected to the router with Ethernet cable after the router was moved?
Does the web administration Attached Devices show the satellite connection as Wired?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DanyP wrote:if I am connected to the same switch as the RBS850 via LAN wire,
Is there a switch between your RBR850 and RBS850? If yes, what is the brand and model (we have had issues particularly with managed switches that cause satellite disconnects)? Explaining your network topology details will help the community diagnose other possible root causes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the size of your home? Sq Ft or Sq Meters?
What CAT# lan cable are you using? CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This RBS850 remains connected to the router with Ethernet cable after the router was moved? - YES
Does the web administration Attached Devices show the satellite connection as Wired? - YES
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are two switches between the RBR850 and the RBS850. Firs node GS108Ev3 and second node GS105Ev2, both with the latest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the size of your home? Sq Ft or Sq Meters? - 40m2 per floor
What CAT# lan cable are you using? CAT6 is recommended. - CAT7
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, nothing in your home network topology seems off. Can you be more specific about the issue you're reporting:
- Is it just that your devices (Windows PC and Apple devices) are connecting wireless to the more distant RBR instead of the RBS?
- Do you lose internet connectivity on your devices when this occurs? Or is there a noticeable performance drop?
Many Orbi clients ask why their devices don't connect to the closest RBS and often this is just because all of the Orbi units are broadcasting a strong signal (reducing power is a frequent recommendation). However if your devices are losing internet connectivity then that is a different issue to diagnose.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you disconnect the RBS from the switches and see if the behavior changes?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not about the loss to the Internet. All devices lose contact with the RBS850. How can the performance of a WLAN account be adjusted?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did. The RBS850 has connected to the RBR850 via WLAN. The quality of the connection is output as 'poor'. The behavior is the same as when the RBS850 is on the LAN. Suddenly the connection is gone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your RBS is in the attic, is this attic space well cooled and ventilated?
Sounds like you may have a faulty RBS.
I would contact NG support and see what your options are:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem isn't solved. Since this week I have many outages. I'll contact the support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might update FW as well:
v.5 has known issues with mysterious reboots and disconnections.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
