Mikely
Jul 19, 2024Aspirant
I need to disable the 5 GHz band
I can't connect a 2.4 GHz device and need to login to my router, but I can't login. No option to reset password.
What router do you have?
Are you logging into it using the app?
Using the browser?What error are you getting? or where are you finding issues?
- MikelyAspirant
RBK853, Bresser weather station.
I used a browser, but http://192.168.1.1 opens something from Zyxel, useless.
Everything I have is 5 GHz, but I need to temporarily disable the 5 GHz band to connect a 2.4 GHz only device.
What FW is loaded on the system?
v7 FW has the ability to setup a IoT network that you can use to get 2.4Ghz only devices connected.
https://kb.netgear.com/000064267/How-do-I-enable-or-disable-the-Internet-of-things-IoT-network-on-my-Orbi-WiFi-6E-System
https://kb.netgear.com/000064269/How-do-I-change-the-Internet-of-things-IoT-network-name-SSID-and-password-on-my-Orbi-WiFi-6E-SystemThe main WLAN can't disable the 5Ghz radio.
