Yahey's avatar
Yahey
Issue to have ORBI app detecting my installed ORBI network
Hello Community,
** As requested, I'm opening a dedicated thread for my issue **
I have an issue to have ORBI app detecting my installed ORBI network.
My ORBI network is working just fine. I have access to the web console of the routeur using a web browser.
But, when installing the Android ORBI app, the installation of the app works fine but not the setup.
I'm stopped at an early step when the app tries to detect the ORBI network.
It ends up with the error saying that my ORBI network cannot be detected.
Except that I'm connected to the ORBI network and having acces to Internet. :)
Here are some further information :
> Installed firmware = NETGEAR Orbi 2.12.6.1824
> Smartphone used = Google Pixel 5
> There's no other ORBI network around.
> I unactivated mobile data on the smartphone to be sure to used ONLY Orbi WiFi LAN connection.
> Connection to web admin interface works just fine.
> ORBI routeur (RBR750) is connected to my ISP box. ISP box has its own IP range and ORBI routeur gets a DHCP reserved IP address by the ISP box. Then, ORBI router has its own IP range.
Any idea ? Thanks.
Kind regards,
  • plemans's avatar
    Your ISP gateway has its own routing functions and causes a double nat.
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
    • Yahey's avatar
      Yahey
      Hello,
      As option 1 is not possible on my ISP box and I need the routing functionnalities (option 3), I went for option 2 (DMZ for not having kind of double NAT).
      Unfortunately, the issue remains unchanged.
      I uninstalled/reinstalled the app.
      My ISP box has no WiFi activated.
      • FURRYe38's avatar
        Try isntalling Orbi app on a different device.
        Try option#2 in the suggested items for avoiding double NAT.
        Yahey wrote:
        Hello,
