Polemos
Jul 29, 2024Aspirant
Orbi RBK863SB AX600 Tri Mesh Wi-Fi 6 - 3 Pack
Hi I'm looking for some advice please, I need to improve my Wi-Fi in my house, single floor, but L shaped property, 23 meters wide by 35 meters long building, with each part of the L being approx. 11 meters wide. Walls are all timber framed with wool insulation and Plasterboard.
I have the ability to place a (relatively) centrally located base station connected by Ethernet to my current Modem/Router which I want to continue to use as its also connected to my Alarm and Security system, external watering system and a few other network connected items such as audio and Video distribution panels. my plan is then to setup the two Satellites that come with the 3 pack in appropriate locations so they still talk to the base station but also give adequate coverage of the required areas, the question is does this sound like a feasible plan? and also the specifications on the RBK863SB suggest it is a router only, but I am guessing I will need to set it up as an Access Point so it pulls IP addresses from the existing modem/router DHCP server. is this something i can do easily with the RBK863SB?
Cheers.
Page 85 of the User Manual describes how to put the router into Access Point (AP) mode:
https://www.downloads.netgear.com/files/GDC/RBK863S/RBR860_RBS860_UM_EN.pdf
I am concerned that 35 meters is too great a distance to get good coverage from one AP placed at the connection of the two wings and the other some 16-17 meters away. Do you plan to connect the two satellites to the router unit with the default WiFi connection or with Ethernet cable?
(At the very least, I would want to purchase this from a vendor with a liberal return policy.)
- PolemosAspirant
Hi thanks for the info, yes I was a little worried about that, I'm assuming the standard working distance from base to satellite is around 9 meters from all the google searches I've done? is there anywhere that gives an expected radius of coverage for each of the base/satellites?
I have seen internet references to -67dB being the "cut off point" between good WiFi signal and poor.
This one says -70dB
https://www.metageek.com/training/resources/wifi-signal-strength-basics/
I have found Heat Map apps to be quite useful when investigating WiFi coverage. There are a number of free apps for Android. Tablets are easier to work with because phone screens are to small. There is also Net Spot for Windows. (Maybe iOS?)
Or, you could see how far the existing WiFi coverage goes. Install the Ookla Speed Test app on anything portable (laptop, tablet, smartphone). Run it in the room with the existing WiFi router.
Record the WiFi RSSI or Link Rate and the Speed Test result, then go from one room to the next and see where performance drops too far.
WiFi transmit power is strictly regulated by the FCC (US. other countries have similar agencies)
