Orbi WiFi 7 RBE973
Reply
Orbi RBR750 randomly disconnects/reboots, and loses config settings
quaywe
Tutor
My RBR750 randomly reboots 1-2 times per day (that I notice).  This has been happening for around 6 months though seems to have gotten worse in the last 3 months.
When this happens:
  • I leave it for a couple of minutes then the WiFi network reappears. I reconnect to the WiFi, but there is no internet.
  • If I wait another couple of minutes the router will usually reconnect to the internet by itself.  However, sometimes it won't.
  • When it doesn't reconnect automatically I connect to the web admin portal for the router and see the setting enabling VLAN/Bridge Settings (required by my ISP) config has gone.  I re-enable it, save settings, and generally within a couple of minutes it will reconnect.
There is no real pattern to this other than it seems to happen roughly once mid-morning, and once mid/late-afternoon.
My setup:
Troubleshooting steps taken to date:
  • Reboot (obviously)
  • Factory reset, re-import previous router config from file.
  • Factory reset, manually reconfig router settings.
  • Turn off Satellite.
  • Turned off any settings I can such as UPnP, private VPN/DNS (go back to ISP DNS), dyn-DNS, etc.
  • Changed from 100Mbps to 900Mbps fibre (that has worked a couple of times for me in previous houses with ADSL/VDSL).
I'm not sure what to do next, but this is really driving me nuts as we often work from home.
Any help welcome, especially from @FURRYe38
Thanks in advance.
Message 1 of 8
Accepted Solutions
Guru
Re: Orbi RBR750 randomly disconnects/reboots, and loses config settings
Message 2 of 8
All Replies
Guru
Message 2 of 8
quaywe
Tutor
Thanks.  I finally figured out how to enable email logs today (app pwd) so will keep an eye on the uptime (and logs) from here.
@FURRYe38 would it help us/you troubleshoot if we enabled debug logs and/or packet capture from the debug page?  Those are pretty verbose so not sure how much is retained, what happens to them when memory full, etc.  But thought I would ask.
Cheers
Message 3 of 8
Guru
It's up to you. Were mostly checking to see if email logs help your RBR stave off these mysterious reboots that some of us see...
Message 4 of 8
quaywe
Tutor
Looking good!
System Uptime: 5 days 19:29:04
Message 5 of 8
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 6 of 8
quaywe
Tutor
System Uptime: 10 days 14:50:04
Message 7 of 8
Guru
NICE.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2916 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
