JCCalifornit's avatar
Mar 01, 2022
Orbi RBR850 - Magenta light on and will not connect to internet.
Hi,
My Orbi router will not connect to the internet. The magenta light remains on. Issue started after a reboot of the router. TS steps below:
1. Restarted router.
2. Reset router using button on back.
3. Unplugged router and satellite and left off all night. Replugged in all connections in morning. Same issue.
4. Factory reset device - same issue.
5. Can confirm modem for NBN works fine.
6. During factory reset I got an error stating that it was unable to set the provider info.
Any help would be greatly appreciated.
Kind regards,
Jason Cowley
  • plemans's avatar
    what modem/gateway is the router connecting to?
    What firmware are you on?
    • JCCalifornit's avatar
      JCCalifornit
      Tutor
      Thanks for the response. It is connected to a NBN network connection device for FTTC connection. All of the connection light are up on the NBN device. Router firmware is V4.6.3.16_2.0.51.
      Thanks
        JCCalifornit
        Tutor
        In addition to my last post. I’ve just tried with another router and it works fine. It seems that the router is not saving any configuration settings that I input.
