Orbi WiFi 7 RBE973
Reply
Orbi RBR860 Speedtest at 3600+ Mbps but devices connected to 5Ghz only got ~900 Mbps
VeryCB
I'm on a hyperfiber 4 Gbps plan from my broadband provider and using RBR860 as the router, directly connected to the fibrebox via the 10 Gbps port.
Then I tested the internet speed with Orbi app (the test is from RBR860 to the internet) and got 3656.11Mbp for downloading and 3664.63Mbps for uploading, which is promising.
However, when I tried to use my iPhone 15 Pro (latest model, should support Wi-Fi 6 and 802.11ax) besides the RBR860, the speedtest result is around ~900Mbps for both downloading and uploading.
Then I tried to switch the device from the iPhone 15 Pro to latest Lenovo Legion model (which supports 802.11ax), got a similar result of ~900 Mbps.
I understand that the device could get slower speed comparing to the router -> internet test. But dropping from 3600 Mbps to 900 Mbps is quite unacceptable to me.
Any idea about the cause of the huge difference? Or how should I get a higher speed on my device?
Thanks!
Message 1 of 11
Accepted Solutions
CrimpOn
Guru
Re: Orbi RBR860 Speedtest at 3600+ Mbps but devices connected to 5Ghz only got ~900 Mbps
WiFi speed is a complicated subject. Internet search will provide reasons why a WiFi6 device will have a maximum theoretical Link Rate of 1200Mbps assuming that a two antenna device is using the full 80MHz wide channel.
https://dongknows.com/wi-fi-6-explained/#:~:text=For%20example%2C%20via%20an%2080MHz,1200Mbps%20or%2...
Real world experience is always lower than the theoretical maximum:
https://www.reddit.com/r/HomeNetworking/comments/114622t/realworld_speeds_from_wifi6_aps/?rdt=35870
Message 2 of 11
All Replies
CrimpOn
Guru
Message 2 of 11
donawalt
Mentor
I have an iPhone 15 Pro and the Orbi 960. I get up to around 1400-1500 Mbps D/L with it.
If your iPhone is getting around 900, that suspiciously looks like the iPhone is using WiFi 5, not 6. I have seen the phone get stuck like that, and sometimes needs WiFi turned off/on, or even a restart.
If you use the Orbi app, run it on your phone, tap Device Manager, find your phone in the list, and tap the name - you will see something like this. Is it on 6 GHz?
Also - how far away from the router are you when you run the WiFi speed test?
And, what version of firmware are you running on the 860?
Message 3 of 11
CrimpOn
Guru
The Orbi 860 is a WiFi6 product.  Orbi 960 is WiFi6E.
That may explain some of the observed difference in performance.
Cisco had this to say about WiFi6 vs. WiFi6E
https://www.cisco.com/c/en/us/products/wireless/what-is-wifi-6-vs-wifi-6e.html
The attached image shows the device connected to WiFi6E (6GHz).  I would not be surprised for it to have higher performance, although a Link Rate of 6Mbps is the lowest possible Link Rate.
Message 4 of 11
donawalt
Mentor
@CrimpOn yes but Wifi 6 does faster than 1G - that's why I suspected the phone may be connected to 5 GHz - I see it all the time here, and with my Mac also. Whether it's an Apple or NG problem, no idea. But frequently it requires a WiFi toggle off/on or device restart. 900 Mbps looks suspiciously like the ceiling for 5 GHz.
Message 5 of 11
CrimpOn
Guru
The Orbi 860 specs say it does not include a 6GHz radio.
https://www.downloads.netgear.com/files/GDC/RBR860S/RBR860S_TS.pdf
So, yes.  The iPhone 15 Pro is definitely connected to the user facing 5G WiFi of the Orbi 860.
Message 6 of 11
donawalt
Mentor
@CrimpOn wow! And yet at the top it's called a WiFi 6 Router! Yet I see where the radios are WiFi 5!
Look here - https://www.netgear.com/home/wifi/mesh/rbr860s/
It says  this - what's going on? But if it's truly 5 GHz there's your answer - that's 920Mbps or so max d/l speed.
Message 7 of 11
CrimpOn
Guru
True.  The numbers in the WiFi Alliance names do not refer to frequencies:
https://en.wikipedia.org/wiki/IEEE_802.11be
Message 8 of 11
VeryCB
Thanks for your information!
Seems like I need to upgrade the router to Wi-Fi 7?
Maybe RBR970?
Message 9 of 11
donawalt
Mentor
With an iPhone 15 Pro you'll get around 1400 Mbps d/l speed max with the 960 series. that's what I see here. The 970 will have even a little better radio/WiFi range (the 960 is excellent though), the 970 will support the WiFi 7 standard in the chart above, so it will offer a measure of future-proof protection. So either 960 or 970 will improve what you see now - imho your choice is based on budget vs. future-proof.
Note, you will not get above 1400 Mbps d/l or so, nowhere near 3600, on any WiFi - you need direct connections for 3600.
Message 10 of 11
CrimpOn
Guru
"need" implies that a WiFi speed higher than 900 Mbps is essential.  Streaming 4K video requires about 25Mbps.  How much bandwidth is required for the apps run on an iPhone?
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2071 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
