Orbi WiFi 7 RBE973
Reply
Orbi RBS350 Continously Blinks White
mikeymikemik3
After moving locations, one of my satellites stopped working and the Orbi app is unable to identify it.
I already tried doing a hard reset and its just continously blinks white.
The firmware version is also updated (V4.4.0.10)
I tried contacting support as the product is still under warranty. But my request was ignored and closed even after I provided sufficient details.
Has anybody faced any similar issues?
Message 1 of 7
Accepted Solutions
mikeymikemik3
Re: Orbi RBS350 Continously Blinks White
Is 3 meters enough distance? I've pressed on the sync button and its blinking white for quite a long time now
Message 5 of 7
All Replies
Guru
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Does the RBS appear in the RBRs web page at all?
Message 2 of 7
mikeymikemik3
I literally placed the satellite almost right next to the router. The RBS does NOT appear in the RBRs web page at all.
Message 3 of 7
Guru
Try at least 10 feet away from the RBR. Next to the RBR is too close.
Is a prior RBS entry on the RBRs web page exist or nothing is seen here?
Press the sync button on the RBS then on the RBR and let it sync.
Message 4 of 7
mikeymikemik3
Message 5 of 7
mikeymikemik3
it took some time but the blinking is now gone
Message 6 of 7
Guru
Be sure the FW on the RBS is the same as whats on the RBR.
3 meters is a good distance to do a initial sync to the RBR while in same room as the RBR.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2977 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
