Orbi WiFi 7 RBE973
Reply
Orbi Router R850 router gives woefully slow Wi-Fi speeds, but when hardwired delivers blazing speeds
TheTiz
I have had the 750 before the 850 and had the same issues. I have talked to at least 10 different techs and made all kind of adjustments to the settings, but nothing works.
My modem is provided by the ISP and it's speeds are all blazing(read by one of their techs) hardwired to his meter. They have checked the connections outside my house. Everything looks great. The router has been hardwired also.
Bewildered
Message 1 of 12
Accepted Solutions
TheTiz
Re: Orbi Router R850 router gives woefully slow Wi-Fi speeds, but when hardwired delivers blazing sp
Hmmm... tech said it was a sagecom and that it was just a modem. After 5 days from the purchase and installation the speeds are starting to increase, especially in the early morning hours. the room that is further away from the router is getting the strongest wifi signal( consistently in the mid 400s mps) the satellite is 15 feet away. The satellite is roughly 30 feet away from the router, in view of the router.
 TIA for all yor input and help
Tiz
Message 9 of 12
All Replies
Guru
What wifi devices do you have connected and speed testing with?
Message 2 of 12
TheTiz
Thank you. I will give requested info when I get home
Message 3 of 12
Mikey94025
Hero
You can also follow the steps in the community FAQ to help ascertain where the speed drop is happening, also whether it is just wireless vs. wired: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Community-FAQ-My-Orbi-speeds-are-slo...
Message 4 of 12
TheTiz
Speetest with OOKLA
Devices 24:
thermostat; 3 tvs; 2 alexa devices; iphone; mac book pro; 3 apple tv boxes; nest protect; nest doorbell; 3 nest cameras, rainbird irrigation manager;2 liftmaster garage door openers
The net gear techs believe i have plenty of coverage.
Thanks for any help and input
modem: spectrum/ stagecom
Message 5 of 12
TheTiz
Message 6 of 12
TheTiz
Firmware:vr.6.3.16
Message 7 of 12
Guru
If you mean Sagecom, these branded modem usually have a built in router and Wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@TheTiz wrote:
Firmware:vr.6.3.16
Message 8 of 12
TheTiz
Tiz
Message 9 of 12
Guru
Enjoy. 📡
Message 10 of 12
TheTiz
Thank you. I will backup the router settings... next time
Message 11 of 12
Guru
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1811 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
