Orbi WiFi 7 RBE973
Reply
RBK752 - Awesome but disconnects on facetime a lot
Foden
Apprentice
Re: RBK752 - Awesome but disconnects on facetime a lot
Not sure if this will work, but worth a shot
Is your EE Smart Hub setup as a DHCP server? If so, turn OFF DHCP and change the routers IP address to a static IP of 10.0.0.1
On the Orbi router turn ON DHCP, if its off, and set the router to have a static IP address of 10.0.0.2 and adjust the IP range it provides to start from at least 10.0.0.3
e.g.
10.0.0.1                EE Router            Static IP                 DHCP Off
10.0.0.2                Orbi                       Static IP                DHCP On
That puts all your devices on the same IP subnet – may need to tweak other settings but give this a shot
If it doesn’t work take screen shots of the settings you changed on the EE router and those on the Orbi, as well as the Internet Setup Page
Message 101 of 113
mnichollsuk917
I’m back home tomorrow, can’t wait to try this and see if we can get this resolved finally!
Message 102 of 113
Guru
Message 103 of 113
mnichollsuk917
Hey,
yes i can get to both of those addresses from the same machine
Message 104 of 113
mnichollsuk917
Hey, if followed the guidance and changed the DMZ to on and selected
192.168.1.92 RBR, This is the IP address i found on the orbi page which is labeled as "internet port" on the advanced section - so ive put this in the DMZ section on the EE router and disabled both wifi radios
I have ran the below again and it looks the same to me?
Tracing route to google.co.uk [142.250.187.195]
over a maximum of 30 hops:
1 6 ms 4 ms 4 ms 10.0.0.1
2 5 ms 4 ms 6 ms eehub.home [192.168.1.254]
3 18 ms 19 ms 19 ms 172.16.15.137
4 * * * Request timed out.
5 21 ms 21 ms 21 ms 213.121.98.136
6 21 ms 20 ms 42 ms 87.237.20.132
7 24 ms 23 ms 25 ms 74.125.52.216
8 20 ms 21 ms 22 ms 209.85.249.149
9 20 ms 21 ms 20 ms 142.251.54.35
10 21 ms 20 ms 21 ms lhr25s33-in-f3.1e100.net [142.250.187.195]
Message 105 of 113
Guru
It will look the same for a trace route. DMZ won't change how the trace route results. That will still see the router and ISP router/modem in the line.
Message 106 of 113
mnichollsuk917
ok, how do i know if the double NAT is fixed? I just tired facetime and it disconnected on the first attempt after making the change
on the EE page there is a setting to turn on "Enable SIP ALG" this is currently off
Message 107 of 113
Guru
So still happening.
Seems that something with your ISP modem is problematic with putting a external router online with the ISP mode and even using DMZ, something is still failing for FT...
Message 108 of 113
Foden
Apprentice
Have you tried my suggestion msg #101? If not undo the changes you made for the DMZ settings and give it a try
Message 109 of 113
mnichollsuk917
Hey guys I haven’t done anything else yet as I have just discovered the issue is now happening when the phone is connected directly to the EE ROUTER! Assume this is an ISP Issue! I couldn’t believe my eyes when it was disconnected directly from the EE router
Message 110 of 113
Guru
Ah ha. Ok. Something to contact the ISP about and see.
I'd check a online search for anyone else having FT problems with iPhones as well. Just to be sure this isn't a FT app or Iphone issue...
Message 111 of 113
mnichollsuk917
 OK, so i thought i would give you all an update.
Problem still persitis,
I have tried:
A brand new phone
A friends phone with his profile
On mesh
on EE router directly
and the newest thing... EE sent me a new router and the problem still persists!!
only thing i can try now is an ISP!
Message 112 of 113
Guru
Message 113 of 113
Top Contributors
Discussion stats
  • 112 replies
  • 4140 views
  • 8 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
