MrYayez03's avatar
Nov 08, 2024
RBR350 - Port Forwarding issue
Hi all,
I am trying to host a content manager server so my friends and I can play, but I am having considerable difficulties.
I have done it once before and managed to get it working but not sure what I'm doing wrong with our new router.
I have setup port forwarding on 9600 UDP & TCP and 8081 TCP. Both these have my laptops static IP of 192.168.1.109. But when I launch the server I get the below error.
10:48:24.203: ‽ RESPONSE: ERROR,INVALID SERVER,CHECK YOUR PORT FORWARDING SETTINGS
10:48:24.203: > CONNECTION TO LOBBY FAILED, ATTEMPT NUMBER  1
Content manager has these ports set as default and I have confirmed they haven't changed.
When I run a port check on the above ports it still shows that they are closed, but they should be open. I also have some remote play port forwards for my PS5 and they work fine.
I have ensured my Windows Firewall has an allow rule for the ports, along with the acserver.exe program.
I have also changed my internal IP address numerous times with no success.
I am running windows 11 pro.
Any suggestions are greatly appreciated.
Many thanks team.
  • Hi all,
    Just thought I'd let everyone know, after speaking with my ISP, they have assigned me a static IP and it all works good now.
  • CrimpOn's avatar
    CrimpOn
    The most common cause of port forwarding issues is having "two routers" (often called "Double NAT") when the ISP device is a router and the Orbi is in 'router mode'.  Since the PS5 forwarding appears to be open, that is probably not the case here.
    Another is that Windows has separate rules for private and public networks.  It might be worth ruling out the Windows Firewall by disabling the Firewall (temporarily) to see if that makes the forwarding successful.
    • MrYayez03's avatar
      MrYayez03
      Tutor
      Thanks for the reply, I have already tested with the windows firewall disabled for all networks and it made no difference unfortunately.
    • CrimpOn's avatar
      CrimpOn
      How are you testing for open ports? (using one of the web sites, "is this port open?")
      Since starting the server immediately causes an error, this might be something to ask about in the forum for the Content Server.
        MrYayez03
        Tutor
        Yep, using the below two websites.
        https://canyouseeme.org/
        https://portchecker.co/
        I have asked the question on Reddit as Content Manager has no official forum, but none of the suggestions worked for me.
        Just annoying me as I do this for work on the daily, port forwarding to VOIP servers, but cant get it working for myself haha.
