- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS350 keeps restarting
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RBR750 with two RBS350 satellites. One of the satellites keeps restarting - it'll start flashing white, then a few minutes later go solid blue. Then a minute or two after that it'll start flashing white again, and it keeps repeating this cycle.
What I've tried:
1. Moving the satellite nearer to the router
2. Remove from router, factory reset, re-add
3. Uploading recent firmware from Netgear site (which is actually older than the automatically updated firmware)
None of these have made any difference. Based on what I've read in here, it seems this is likely a hardware failure. The Netgear support site keeps throwing an error whenever I try to create a support case, and I can't find any other method of contact.
Hoping somewhere here has an idea on how to address this. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS350 keeps restarting
What Firmware version is currently loaded on the RBR and RBS?
What is the distance between the router and 📡 satellite(s)?
Does swapping RBS around change the behavior>
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR750 firmware - V7.2.6.21_5.0.20
RBS350 firmware - was V4.6.14.3, I later uploaded the version on Netgear's site which is V4.4.1.29
Home size - main house 1200sq ft with a 200 sq ft detached garage. Router is back of main house with a satellite in the garage (works perfectly) and one at the front of the house which is the one that's failing.
Distance is usually around 50 ft and it's been working perfectly for ~7 months until it started failing recently. As mentioned earlier I've tried moving to middle of the house (around 20 ft) and in the same room as the router, and the behavior is the same.
Not sure what you mean by "swapping RBS around"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK you need to downgrade the RBR back to v4 FW.
Please review all the information here:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for sharing. I'll try this. I actually upgraded to v7 when this started happening to see if that would fix it (v7 clearly states it improves stability!!) so I'm not too optimistic this will work, but I'll report back when done.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since you have the RBR750 and RBS350, the RBR can't not be updated to the RBK version of FW. It's not compatible with the RBS350s.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I installed the same firmware across the router & both satellites. it still reboots in its current location, but if I move it nearer to the router it appears to be stable & not reboot. This doesn't really help my layout (and doesn't explain why it's been working fine in this location for months), but I guess I need to explore either wired backhaul or another satellite for daisy chaining.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Somehow the signal at that location may have gone bad or could be some interfences. If you moved the RBS closer to the RBR and its' stop cycling, means the RBS has found a stonger signal to the RBR.
Ya if you can get get ethernet BH running, it's highly recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actually I take that back.. it's still rebooting even placed nearer to the router, just not as often.
I'm thinking this is a hardware issue. I'm going to contact support and get a replacement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
