Orbi WiFi 7 RBE973
Reply
VPN ip address change
vblack
Star
Hello.
I have two systems RBRE960 and RBR850. Both activated VPN service. The problem is that they both have save VPN IP/subnet 192.168.254.1, so I could not connect to both of them at the same time, which is needed to me. Previously one of the system was SRR60 and it's VPN IP address was at least somehow controllable (it was LAN subnet +1).
Am I missing and it is able to be changed somehow in either RBRE960 or RBR850?
Thank you.
Message 1 of 13
ekhalil
Master
Re: VPN ip address change
Why don't you change the IP range in one of the systems to something else, e.g. 10.0.0.x. ?
Message 2 of 13
vblack
Star
Systems had different ranges
192.168.5.0 and 192.168.10.0, but vpn on both 192.168.254.0. I will try to change dramatically to 10.10.x but I highly doubt it will change VPN ip
Message 3 of 13
ekhalil
Master
It should
Message 4 of 13
CrimpOn
Guru
Was that a typo? (192.168.254.0 vs. 192.168.254.1)
Netgear changed IP subnets around from the original product line, where every device was in one subnet (primary & guest) and VPN clients were assigned from the next higher subnet starting at 2 (the router takes 1).  The AX line introduced a separate subnet for the guest network.  Are there even more subnets in the 960 product line? (IoT?  6E?)  I could see an engineer wondering, "Where do I put VPN if (a) guest network is enabled, or (b) guest network is not enabled?"
Just an idle question: When more than one VPN connection is active, do the IP addresses go "up", i.e. 192.168.254.2, then 3, then 4?
Message 5 of 13
ekhalil
Master
Yes, 192.168.254.2, then 3, then 4
Message 6 of 13
vblack
Star
Well it is not.
I have changed RBRE960 router lan to 10.10.10.0/24 and VPN address still 192.168.254.2
While second router RBR850 lan 192.168.5.0/24 with VPN address also 192.168.254.2
Am I missing something?
Thank you.
Message 7 of 13
ekhalil
Master
Ok, then seems that 192.168.254.x is hard coded in Orbi.
Previously when the CLI interface (telnet was open in Orbi we could easily change this, but unfortunately now I don’t think there is anything we can do.
Message 8 of 13
CrimpOn
Guru
What parameter would one set using a command line interface (telnet) to manage the IP subnet assigned to VPN connections?
  1. Idle curiosity.  Would like to see what happens when I try it on a test system.
  2. I have heard rumors of a way to enable telnet on the AX products  This might prove to be a solution to this specific circumstance.
Message 9 of 13
ekhalil
Master
Only the following parameter needs to be changed:
openvpn_tun_ipaddr=192.168.254.1
Message 10 of 13
CrimpOn
Guru
A puzzle.  I do not find a parameter openvpn_tun_ipaddr
on my RBR50.  Is this parameter unique to the AX models?
.... Or, am I just not looking for it correctly?
Message 11 of 13
ekhalil
Master
Yes, this is only in AX models. In the AC models VPN don’t give the 192.168.254.x addresses. Completely different
Message 12 of 13
vblack
Star
So, as an update - I have official answer that VPN address could not be changed at the moment on AX Orbi.
They suggested to create feature request, so I did:
https://community.netgear.com/t5/Idea-Exchange-For-Home/Add-ability-to-change-the-VPN-Client-Device-...
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3780 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
