Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Best setup for Orbi with ATT Fiber
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-07-07
09:57 AM
2017-07-07
09:57 AM
Just bought Orbi two unit set up to connect to my AT&T Fiber gateway. I've read several blogs and youtube videos. All have different ideas on how to set this up. Most suggest putting the fiber gateway in bridge mode then setting up the Orbi. Others also suggest turn DHCP off on the gateway and letting Orbi assign dynamic IP addresses. Thoughts?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-07-10
09:58 AM
2017-07-10
09:58 AM
Re: Best setup for Orbi with ATT Fiber
Hello GeorgeJetson
Its whatever will work best for you if you like or are using alot of the advanced features on the ATT router then you can just disable the wifi on it and then use the orbi as AP.
DarrenM
Message 2 of 2
Announcements
