×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Can Orbi satellite get info via wired ethernet (not just wired backhaull)?
jblakely
Follower
To Netgear  re RBK 44
I have a celing mounted Wi-Fi Access Point, WNDAP360 which is old and doesn't cover my entire home of 6,000 square feet.  I am having trouble as it won't update the firmware and it doesn't work well.
I am considering an Orbi system.
I have wired Ethernet to many rooms but I have a bedroom that is too far away to get any Wi-Fi signal, however it has wired Ethernet.
I know the Orbi uses wired backhall.  But my back bedroom gets no Wi-Fi so can the Orbi satellite get its information from the router by wired Ethernet?
Wired backhall takes a signal from the satellite to the router but does it also supply information the other way from the router to the satellite??
Model: RBK30| Orbi AC2200 WiFi System
Message 1 of 2
Guru
Re: Can Orbi satellite get info via wired ethernet (not just wired backhaull)?
Yes it can:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Do you have any ethernet switches in use in the house? If so, Mfr and model# of these switches.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 423 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
