× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Code 404 and no internet signal with Orbi RBK 50
thwat
Tutor
Hello there,
I just got a netgear orbi RBK50 but I am having some issues:
1. When trying to connect to some sites it does not work and gives me a 404 error. I tried to connect with the wifi emitted by the modem and the site works.
2.On my mobile phone it says that the wifi does not have internet but I am able to use it with most common tasks. Some things do not work such as the google play store (downloading)
3.I believe that it is connected to the first two but I am also having issues with connecting to some apps on my laptop so i am unable to login.
if you might know an answer I'd ne happy to hear it.
Thanks.
Message 1 of 8
Guru
Re: Code 404 and no internet signal with Orbi RBK 50
Power OFF the ISP modem and RBR for 30 seconds then back on.
Has a factory reset and setup from scratch been performed since last FW update? YOu might do this and walk thru the setup wizard with a web browser connected to the RBRs web page at orbilogin.com
@thwat wrote:
Hello there,
Thanks.
Message 2 of 8
thwat
Tutor
I'm a bit lost with what you said but you want me to reboot my router and go through the setup once again?
Message 3 of 8
thwat
Tutor
But the orbi is brand new
Message 4 of 8
tomschmidt
Virtuoso
@thwat, did you enable Armor and/or Disney Circle when you setup the router?  If so, they could be blocking some of the web sites you are trying to access, thus giving the "404" error.  If you enabled them, please disable them and try the sites again that are giving you issues.  If they are the cause of the errors, then I suggest posting on the community forum in the sections for Armor and/or Circle.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 5 of 8
Guru
Try the reboot of the RBR first and power OFF the ISP Modem for 30 seconds then back ON. If the RBR doesn't get connected. Reset the RBR and walk thru the setup wizard.
Message 6 of 8
thwat
Tutor
I wil try
Message 7 of 8
thwat
Tutor
I will do it this evening because people are using the network
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1126 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
