ronothan's avatar
Jul 20, 2019
Different SSID
Would love love some help with setup
I have a router which is used for one business and has the SSID “business-wifi”. This modem/router connects directly to the internet.
I’d like to set up the Orbi via wired backhaul to the business-wifi router, with a different SSID called airbnb-wifi
How would I set that up?
And also, can I have the satellites connect to the business-wifi via wired backhaul without a problem!?
  • FURRYe38's avatar
    Please post about this over on the main Orbi forum:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    You would probably run the Orib system in AP mode:
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    No the RBS have to be connected to the back of the RBR or RBR via a ethernet switch connected to the back of the RBR an the RBS connected to this LAN switch.
  • CrimpOn's avatar
    CrimpOn
    Yes, you can do this.
    Connect the Orbi to the existing router with ethernet.
    Set the Orbi in Access Point (AP) mode.
    Disable the SSID broadcast on the primary network.
    Name the Guest SSID "airbnb-wifi" and give it an appropriate password.
    Do NOT check the box "Allow guests to see each other.."
    Of course, the Orbi could replace the existing WiFi router, but that's not what you asked.
    • ekhalil's avatar
      ekhalil
      Master
      As long as Orbi is in AP Mode you don't need to disable the main router's wifi "business-wifi" if you would like to keep it, and as long as you use different SSID and radio channels for Orbi than for the main router
      • CrimpOn's avatar
        CrimpOn
        I was suggesting to disable the Orbi primary network broadcast and using only the Guest network for the AirBnB.  If guests connect to the Orbi primary network, then they are essentially on the main router's primary network.  If they are on the Guest network, then they are supposed to be restricted to Internet only, and should not see any devices on the main router network.
        I am not sure why an Orbi was chosen for this application, but I imagine the "business" would not want guests hacking away at it.
