- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Divide 5G Orbi RBR350
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've an IoT device to connect to Orbi Wi-Fi, but it need to have a separate SSID for 5G and 2.4G to work. As i can read, Orbi new firmware doesn't allow to divide the two SSID. I tried to switch off 5G from router settings, but when I turn it on again IoT device stop working, I don't know why this works for other users.
Is there another solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Divide 5G Orbi RBR350
Can you please identify the specific device? The device itself has only a 2.4G radio. It cannot detect or connect to 5G. If the customer has only 5G WiFi (no 2.4G at all), then the device has nothing to connect to. This situation would be absurd because all consumer WiFi routers provide both 2.4G and 5G (as does the Orbi).
Is there a specific step in the setup that fails?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you might want to also change the power output of the 5Ghz radio to 25% on the RBR. Turn OFF any RBS while you try this. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
FYI, Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
