×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Mixed wired / wireless and daisy chained back haul?
Nozzer
This closed thread states you can login into a device in your setup directly and configure that one device to be daisy chained even though other nodes are wired/wireless back haul. I've tried logging in (successfully) and can see no options to configure the node "locally". I'm running the latest software ( not beta ).
How do I find the local settings if they're not in the admin menu on the local device? Thanks!
https://community.netgear.com/t5/Orbi/Daisy-chain-ethernet-backhaul/td-p/1696894
Message 1 of 3
schumaku
Guru
Re: Mixed wired / wireless and daisy chained back haul?
@evan2 this is a typical set-up I would expect Orbi and especially Orbi Pro to handle - without any manual intervention.
Message 2 of 3
Guru
Anything regarding configuration of the RBS or RBR is done thru the RBRs web page. Daisy Chain is found under Advanced Tab/Advanced Settings/Wireless Settings. It's recommended to disable Daisy Chain while having a RBS connected in ethernet mode.
You can log into the RBS web page using there IP address however only FW update and checking status features are seen here. Nothing else.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 3
Discussion stats
  • 2 replies
  • 548 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
