CSrider's avatar
CSrider
Orbi RBR50 Router Ports
Hello,
I have an Orbi RBR50.  I was told I need Ports 4500, 500 and 123 open to have something work on it (hard wired).  Is there a way to open these ports?  Do I need a new router?  I need a T-mobile extender. It works plugged in directly to the modem, but my modem only has one outlet.  It doesn't work from the router.  Thanks!
  • plemans's avatar
    Why not put the tmobile extender into the router's dmz? it'll open it up to everything online but that's on tmobile's device.
    • CSrider's avatar
      CSrider
      Thanks for your response!  How do I put it on a DMZ?  I looked it up, but I'm still unsure how to do that.
      • CrimpOn's avatar
        CrimpOn
        On the Orbi RBR50, the web interface is used for this. See page 68 of the user manual:
        https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
        This requires that you first learn the IP address of the T-Mobile device from the Attached Devices display.
        The manual does not mention this, but it is a good idea to take steps to ensure that the T-Mobile gets the same IP address every time the router is restarted (power outages, moving it around, updating firmware, etc.).  This is done by entering the hardware MAC address (from the Attached Devices page) into an entry in the LAN Setup page.  See page 73 of the manual.  Most of us prefer that reserved IP addresses are not in the range of addresses used for the DHCP "pool".
        I see no problem with putting the T-Mobile device in the Orbi DMZ.  I am simply confused as to what would keep it from working when connected to the router.
  • CrimpOn's avatar
    CrimpOn
    Would like to confirm "I was told" by looking at the setup information for this device/software?  What is it?
    If a T-Mobile Extender works when plugged into the modem, it should work when plugged into the router.
    Which model of extender is this?
    (and what is the purpose of using an LTE product with the WiFi router?)
    • CSrider's avatar
      CSrider
      Thanks again.  The T-mobile tech had me plug the "Cellspot" directly into the modem. It worked fine. Unfortunately, the modem only has one ethernet outlet.  I have to plug the router into the modem.  (I have really fast Frontier internet)  When the cellspot is plugged into the router (Orbi RBR50), it doesn't work.  The T-mobile tech said I needed those listed ports open. My cell phone works very poorly at home (for calls) without it.  Everything but call quality is fine.
      • CSrider's avatar
        CSrider
        Oops, forgot to include- Extender: Nokia 4G LTE Cellspot V2 Model SS2FII Femtocell Multiband SOHO
