espressodaily
Dec 17, 2019Aspirant
Orbi RBR50 release external IP
How do I tell the orb to release/renew its external IP? I found article for other netgear routers but nothing for Orbi
It would help to know the reason for doing this.
There is a "Reboot" option on the Orbi web interface, Advanced Tab Home Page. Also, powering off and back on will cause the Orbi to request DHCP. There is probably a telnet command, but I have not found it.
- espressodailyAspirant
rebooting did not work. Verizon FIOS was useless, they said they can't help because I am using my own router.
- JetdriveLuminary
Unless you change your MAC address, you will usually end up with same IP address as you had. Is that your purpose for renewing, to get a different IP?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopBe way to release and renew would be to turn OFF the Orbi RBR for 1 minute. Also I would power OFF the ISP modem/ONT for 1 minute as well. This can sometimes cause the modem to get a new IP address from the ISP.
espressodaily wrote:How do I tell the orb to release/renew its external IP? I found article for other netgear routers but nothing for Orbi
