ermannobonifazi's avatar
Mar 06, 2020
Orbi backhaul goes to wired when should be wifi
My setup is one router + 2 satellite. On one of the satellite I have connected via wire a SKY Q Extender. If I connect the SKY Q when all the WI FI is up, an IP is assigned to the extender by my main DHCP via wire and all works. The issue is that is the ORBI network reboot for some case (power outage for example) that 1st satellite mark the backhaul connection type as wired and the 2nd satellite do not connect in a daisy chain model, just go to the main router (that is more far than the 1st satellite). In fact the connection-type on 1st satellite is market as wired (!). If I detach the SKY Q extender and wait a few than the network riconfigure itself in the right way and the 2ns satellite goes to daisy chain and the first show connection-type (backhaul) as Wifi (5G).
Bug?
  • FURRYe38's avatar
    The RBR is reading the status as wired as the RBS is wired to this extender which correct, however is a odd configuration in the first place. I would use the extender after the RBS and not in between the RBR and RBS. The Sky Q would be the variable.
    • ermannobonifazi's avatar
      ermannobonifazi
      Is not the RBR that is read as wired but the RBS where the extender is connected to acquire the IP, like it would be any other IP device.
      • FURRYe38's avatar
        Thats because its connected wired so it would read as a wired connection...
