Orbi WiFi 7 RBE973
Reply
Orbi not working with Apple devices
MalcH
I have both Orbi RBR50 and brand new Ordi RBR760 (both with the latest updates)
Both work perfectly with Windows 11 devices but will not work with Apple devices (all up to date).
For example Apple devices show:
1) MS Outlook - Cannot verify identity of 'outlook.office365.com cannot be verified'
2) Hotmail - 'Cannot verify the server identity The identity of "m.hotmail.com' cannot be verified
Apps such as 'BBC News' work but BBC Weather', Met Office Weather', Strava' 'Ride with GPS' cannot connect. Safari 'can't open the page because it couldn't establish a secure connection to the server'
Message 1 of 7
Accepted Solutions
MalcH
Re: Orbi not working with Apple devices
Hi all, thanks for all the suggestions, I have now resolved the issue.
What confused me was the fact that all the Apple devices worked initially then over a period of several hours they one by one lost access to the Internet.
The solution:
I accessed the router via the IP address locally and went into Advanced Settings, Control Access and discovered that Intent access was denied to all but my two Windows 11 devices even when the correct password was used to access the router WiFi.
I ticked the boss to allow additional devices to access the WiFi and instantly the issue was solved.
Message 4 of 7
All Replies
Guru
Be sure that you disable WiFi Private IP Address feature on Apple phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Contact Apple support regarding there products.
Message 2 of 7
@MalcH wrote:
....but will not work with Apple devices (all up to date).
Have you considered that it might be the other way round?
Apple devices will not work with your Orbi?
Have you tried researching that side by talking to some Apple experts?
Message 3 of 7
MalcH
The solution:
Message 4 of 7
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 5 of 7
MalcH
Thanks, greatly appreciated.
I have now marked it as solved.
Message 6 of 7
Guru
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1121 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
