pstoric83's avatar
Apr 12, 2019
Port forwarding not working
I have an Orbi RBR20 with the plugin wall satellite that’s functioning ok but I can get port forwarding working for our Hikvision DVR. I made a new custom Rule (Camera DVR) and entered the port range 16000 – 16003 but can hit the DVR box externally. Internally it’s accessible. Yes I gave it a static IP already and UPNP is off. I have https mgmgt enabled on the router I can get to the router login page via IP or DynDNS hostname.
When log into a PC that’s on-site and test via canyouseeme.org for ports 16000 -16003 it shows they are not open. I’m very familiar with Orbi’s as I use one at home but also typically use Unifi, Sonicwall, firewalls so I know how to forward ports.  The Orbi screen makes it very simple but is there a setting I am missing?
https://imgur.com/YqLZ0dj
  • As per the 7.0.4.8 RN this was added (after loooong fights):
    • Introduced an option to enable/disable switch discovery (SSDP/UPnP) protocol
    Something like there, but not near to any switch:
    System -> Management -> Switch Discovery .
    PS. Be aware the devices don't chatter on thier own - you must have systems on your network doing some M-SEARCH multicasts on 239.255.255.250, the reply is sent to the requsting IP as a UDP unicast packet 8-) - so the noise is not caused by the device. And no broadcasts involved by the way, too.
  • FURRYe38's avatar
  • pstoric83 wrote:
    When log into a PC that’s on-site and test via canyouseeme.org for ports 16000 -16003 it shows they are not open. ..............
    Two possible reasons:
    1. The ISP modem/router is blocking the request before it reaches Orbi.
    2. The protocol you used in the port forwarding (udp/tcp) does not match the incoming request. What protocol did you choose?
    • pstoric83's avatar
      pstoric83
      Guide
      I've ahve both TCP adn UDP being forwarded for that port range and that's correct. I use that DVR at multiple locations with the same settings and it works great. Only difference is that they have a Sonicwall instead of Orbi at the others.
      As for modem, don't remeber, will need to check next time I am on-site (not sure when that will be) but the modem shouldn't be blocking it.
        pstoric83
        Guide
        Turns out the port forwarding on the Orbi was working ok. I was finally able to remote into the DVR box from a local PC and ports the security guy said to forward were different from the ones programmed into the DVR box. Once I corrected those to the ones I had forwarding all is working. Thanks for the assistance anyway!
