RamaSubbu_SK's avatar
RamaSubbu_SK
Initiate
May 11, 2022
Router Admin portal says update files for "Orbi Satellite RBW30"
How fix the firmware update failure?
  • CrimpOn's avatar
    CrimpOn
    The first choice is, "if it ain't broke, don't fix it."  i.e. If the WiFi system is not causing any problems, leave it alone.
    The second choice is a manual firmware update, where you:
    • Download the RBW30 firmware from the support web site.
    • Unpack the zip file to extract the RBW30 image file.
    • Connect a web browser directly to the RBW30 satellite web page using the satellite's IP address
    • Select the Firmware Update item on the menu.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello RamaSubbu_SK,
    The firmware update failure is only an issue if the firmware loaded to the device is not current. If the loaded firmware is current please disregard the "error" message. In your case, the firmware is current to date. There is no further action needed on your behalf.
    Best,
    Kevin
    Community Team
