jithin's avatar
jithin
Tutor
Oct 03, 2018
Satellite looses connection and has to restart router to fix
 What I have observed is that the router still has internet and if I move to a room where router is the closest one, I get internet, but the room with Satelite does not have Internet. Restarting router is the only way to bring internet back.
This happens once every 3-4 days, and I am thinking of returning Orbi and get the Google one. Has anyone faced this ? Does changing wifi channels help ?
I have Orbi and 2 Satelites.
Firmware - V2.1.4.16
Number of devices - 15
Guest Network - Yes
Internet Provider - Comcast Xfinity
This issue affects both main network and guest network.
  • FURRYe38's avatar
    Set up an IP addresss reservation for the satellites ON the router.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
    • jithin's avatar
      jithin
      Tutor
      Modem -  Arris Surfboard S86190
      My home is about 1600 sqft
      2.4 Ghz Channel is in Auto
      5Ghz Channel uses 48
      In addition to my Wifi Network I see 10 other Wifi networks.
      Done. WIll monitor how this goes.
      > Fast Roaming
      Already disabled
      > Daisy Chaining
      Disabled Will see how it goes.
      > MIMO
      Already Disabled
      > IPV6
      Already Disabled
      • FURRYe38's avatar
        Also be aware of your SB6190 modem:
        http://www.badmodems.com/
  • FURRYe38's avatar
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
