Orbi WiFi 7 RBE973
Reply
Unable to set static IP on RBR40
marcin_olo
Follower
Hi,
I'm using Orbi RBR40 for some time and after initial setup there was no issue at all. Until now when I wanted to change router's IP address to static address. And now regardless what I set (static or dynamic) it alweys is set to 10.0.0.1 which wass assigned during initial setup.
My Orbi router is connected to internet provider's router which I have no controll on.
My setup look like in attached screenshot.
I'm very gratefull for any advice.
Message 1 of 3
Guru
Re: Unable to set static IP on RBR40
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Build in router here by chance? If so, this may cause the 10.0.0.1 address to be seen on the RBR as the upstream router also maybe using 192.168.1.1...
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 3
Two routers on your network can cause headaches.
What is Double NAT? | Answer | NETGEAR Support
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1111 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
