- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
admin password on orbi satellite (RBS20)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR40 as my main router; I've attached my previous RBR20 as an access point to it. The original RBS20 satellite shows sync'd in both the app and in a web browser. However, the the admin password which I changed on the router is not syncing with the satellite. So, my router at 192.168.1.1 has credentials of admin|mynewpassword, and the satelitte at 192.168.1.8 has credentials of admin|myOLDpassword.
When using a browser to access the satellite, there is nowhere I can see to change the password. How do I change it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: admin password on orbi satellite (RBS20)
My Orbi satellite "learns" the admin password from the router it is attached to. There is no provision to set the admin password on the satellite itself. Have you tried turning the satellite off and then back on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure FW is the same on RBR and RBS...
@cpking wrote:I have an RBR40 as my main router; I've attached my previous RBR20 as an access point to it. The original RBS20 satellite shows sync'd in both the app and in a web browser. However, the the admin password which I changed on the router is not syncing with the satellite. So, my router at 192.168.1.1 has credentials of admin|mynewpassword, and the satelitte at 192.168.1.8 has credentials of admin|myOLDpassword.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
How does that even matter in this scenario? The mere fact that the satellite is online, viewable and reachable already proves that its connected on the same network so its quite obvious that distance cannot be an issue.
"Is the password you are using to access the RBS20 the same password that's on the RBR20?" If yes, then its likely the SAT is synced with the AP and not the router.
"Is the password on the new RBR20 AP the same as the RBR40?" If no, then again it points to the SAT likely being sync to AP and not Router. If yes, then there is a bigger issue because if RBR40(Router) and RBR20(AP) have same pwd and RBS20 doesnt, sync is failing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Distance is a factor on ORBI systems. Too close or to far will cause the wifi overlap and connect between the RBR and RBS to be problematic...thus some will see odd problems like this. Also FW being not the same on the RBS can be problematic as well.
We already know that if the RBS PW is the same as the RBR, then the RBS has synced with the RBR correctly. Which seems to be a problem the OP posted about 6 months ago.
@snikker17 wrote:
"What is the distance between the router and satellite(s)?"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you get this working?
