- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't connect Chamberlain MYQ garage opener to Orbi RBR750
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I updgraded my home network to Orbi RBR750 keeping the same SSID and password. I'm able to connect to all devices, however, myq garage opener refuses to connect.
The firmwire version on orbilogin.com is V4.6.5.14_2.0.54
So far, I've tried this and nothing seems to help:
Unchecked Enable 2.4G and 5G AX mode under Enable AX - This WiFi mode will enable AX features
Modified CTS/RTS Threashold to 1-2347
Unchecked Enable WMM (Wi-Fi multimedia) settings (5GHz a/n/ac/ax)
I keep getting same error everytime:
Missing Network
Looks like there is an issue finding your network. Check the following and try again.
Your home network Wi-Fi can reach the garage with at least 2 bars
You are using a 2.4 GHz network.
As said before, all other devices in garage I'm able to connect but myq.
Any tips to resolve this issue is greately appreciated
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The phone app has difficulty because your phone connects to the 5Ghz network with the same SSID, messing up its attempt to connect MyQ to the 2.4Ghz version. The workaround is to use the alternative way to setup wifi connect (not the app), for example:
- https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Connecting-Orbi-RBK753S-AX4200-to-Ch...
- https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Chamberlain-MYQ-Orbi752-won-t-connec...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Can't connect Chamberlain MYQ garage opener to Orbi RBR750
This is truly bizzare. The garage door opener was already connected to WiFi and working correctly. The WiFi system was switched out for a new system (Orbi RBR750) that has exactly the same SSID/password, and the garage door opener no longer connects?
I replace WiFi routers fairly often, and always use the same SSID/password on the new router, and all of my devices connect automatically.
The Chamberlain app may be poorly written and may not deal well with mesh WiFi when the smartphone is connected at 5G and the opener supports only 2.4G, but there should be no reason to set up the opener from scratch again.
Do I understand correctly that the situation now is that the door opener has been reset and is in setup mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I happen to see these links. The main challenge for me to find the old device compatible to 2.4G --
You just might need to find a compatible 2.4GHz device to help you connect the 2.4GHz Chamberlain/MyQ. Just try multiple devices. Maybe older = better
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks @Mikey94025
I was able to setup myq garage door with Orbi after investing almost 1 day.
Here is what I did:
1) Find a compatible 2.4G device, it could be old phone or laptop. Most phones would automatically connect to 5G and even after shutting down the satellites and moving away from router, phone somehow still connects to 5G.
2) You can find the the device and the connection type in orbilogin.com. Basic -> Attached Devices.
3) I was able to figure that one of my laptop is connecting to 2.4G network. So I followed the link and first post from techdilettante
4) Follow the prompts and first try to Change or update the Wi-Fi settings, if it doesn't work, erase the settings and start again.
5) Once myq is connected to network, follow the instructions to connect to overhead garage opener.
Moral of the story: ditch the myq app for setup if your phone is not able to connect to 2.4G. Setup via laptop works.
Thanks much for all help!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Please mark your thread as solved so others will know.
Enjoy.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
