jimsasselli
Oct 27, 2021Aspirant
ORBI RBK753 - General Quetions
A few basic quetions:
1) The blue light on one of my satellite units occasionally turns blue. I know that no colored lights means normal operation, as such I suspect the light is to simply indicate a temporary loss of connection?
2) My network set-up shows the router connected to Satellite 2 and then Satellite 1 (in that order)...should the order be reversed to 1 and then 2, or is this normal/okay?
3) My network set-up also shows a solid line from the Modem to the Router and a dotted line from the Router to each of the satellite units. I suspect the solid line is to indicate a hard wire connectin via CAT-5 and the dotted line is to indicate a wireless connection...correct?
Thanks,
Jim
- Blue light - no idea
- Order of satellites, #1 is the satellite that appears "on top" on the web display. If the units have chosen to "Daisy Chain", then the unit closest to the router should be the one connected to the router. The farther away unit will be at the "end" of the chain.
An easy way to test is to power off the unit that is farthest away and see what happens.
(p.s. the forum is loaded with complaints that the Orbi 'app' does not show the network connections correctly.) - Correct. Solid line indicates ethernet connection. Dotted Lind, WiFi.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
Thanks,
Jim
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System 📡
2) My network set-up shows the router connected to Satellite 2 and then Satellite 1 (in that order)...should the order be reversed to 1 and then 2, or is this normal/okay? Depends on how you have the RBS placed out from the router and how they were turned on and connected to the router. Got a screen capture of this?
3) My network set-up also shows a solid line from the Modem to the Router and a dotted line from the Router to each of the satellite units. I suspect the solid line is to indicate a hard wire connectin via CAT-5 and the dotted line is to indicate a wireless connection...correct? YES.
- jimsasselliAspirant
