PV23QLD's avatar
PV23QLD
Tutor
Sep 18, 2022
Orbi RBRE960 constantly dropping wifi to iPhone?
I recently purchased Netgears Orbi RBRE960 units thinking they were a great product. Unfortunately the reviews I’ve read recently tell a difference story. Seems they still can’t get the wifi drop outs sorted when using apple products. I have Apple iPhones and other devices monitored by iPhones and constantly getting wifi drop outs. Doesn’t matter what time of day, wheee I am in relation to distances from satellites.
Has anyone had similar issues and managed to find a solution. The Netgear technical support line don’t have any answers either.
Thank you.
  • What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - ZTE ZXHN H268A
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. - yes cat 6 connected
    What Iphone and iOS are you using? - 15.6.1
    What is the size of your home? Sq Ft? -  215 sq meters
    What is the distance between the router and about 10 meters - 30 feet.
    Please turn off 1 RBS if you have two deployed. You may have too much wifi signal for that size of home.
    https://youtu.be/UR0viMLISz4
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. I will try setting manual channel 1 for 2.4Ghz and 40 for 5Ghz and 69 for 6Ghz.
    Any Wifi Neighbors near by? If so, how many? - 6 neighbors <What channels are they using?
    Do you have the IoT and separate 6Ghz radios enabled on the RBR? - yes both enabled. <Are you using the IoT broadcast?
    Please DISABLE the separate 6Ghz SSID broadcast.
  • michaelkenward's avatar
    michaelkenward
    Your subject says "Orbi RBRE960 constantly dropping wifi to iPhone?"
    It  might help to think of it the right away round.
    It is more likely that the iPhone is losing the connection to the router.
    Recent incarnations of the iPhone have implemented a "security" feature that has led to quite a few problems with wifi connections.
    Try starting with this tip:
    Re: NH6700 Router: Cannot access router directly o... - NETGEAR Communities
    • PV23QLD's avatar
      PV23QLD
      Tutor
      Hi Michaelkenward,
      Ive disabled the private wifi (MAC) address on my Iphone 11 Max Pro - version 15.6.1 and will see how that goes
      Thank you
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Can't say I've seen any issues with my iPhone here. 12 Pro max iOS 16.
    Thank you.
    • PV23QLD's avatar
      PV23QLD
      Tutor
      Hi FURRYe38,
      What Firmware version is currently loaded? - V6.5.3.2
      Thank you
      • FURRYe38's avatar
        PV23QLD wrote:
        Hi FURRYe38,
        Couple of options,
