- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 Out Of Sync after upgrade to Firmware 4.6.3.16
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey everyone.
Could someone help me please?
I did an update to my Orbi RBR850 router to the latest firmware V4.6.3.16_2.0.51
Since doing this, the satellite in the bedroom is coming up with an "Out of sync" message on the main router page.
I have tried a re-sync but this has not worked.
When I re-boot the main router, it connects and says "Good" for about 5 minutes and then goes back to "Out of sync"
It is also reporting that no devices are connected to it which is not true as I have a full WI-FI signal when I am close to it and getting nearly 1gb speeds.
I have also done a factory re-set which has made no difference.
The other satellite in the office is wired and is reporting no issues at all.
Is this is firmware problem? Are support aware of it and is anyone else having similar issues?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 Out Of Sync after upgrade to Firmware 4.6.3.16
What Firmware version is currently loaded on the RBS? Be sure the RBS FW is updated to same version as RBR.
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Current firmware version is V4.6.3.16 and is loaded on the router and all the satellites
The modem is a Virgin hub 4 , provider is Virgin
I have rebooted several times
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mode is your ISP modem working in? Router or Bridge mode?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am not sure what this has to do with my satellite being out of sync after a firmware version upgrade?
My Virgin hub is in modem only mode .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Next step would be a factory reset and setup from scratch. I would reset the RBS and then turn it OFF. Setup the RBR to completion. Then turn ON the RBS and try pressing the sync button on the RBS then RBR. I'd do this with the RBS in same room as the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have already done this but I will try this again.
