- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with an iPhone 15 Pro Max
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m having the exact same problem with an iPhone 15 Pro Max. Tried all of the steps mentioned above, running latest firmware as well and i still get intermittent drops on my phone.
It will switch back and forth between wifi and cellular, sometimes i have to manually select the network as it will not reconnect automatically.
I guess we’ll have to wait for another firmware that hopefully fixes this.
I’m not getting any problems with any of my other devices, just my 15 Pro Max which is the only wifi 6E device on my network.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Problem with an iPhone 15 Pro Max
What iOS version is on the phone?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Is 240Mhz enabled on the RBR?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Is Armor enabled or ever been enabled on the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issues here iPhone 15 Pro Max, ios 17.2. It will suddenly go from wifi to cellular, mostly when i am connected to a satellite. When connected to the main router i’ve just seen this happen a few times. Tried already everything mentioned on this thread.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
Please give feedback to the questions presented.
Might update if you see this, if you haven't already:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well not sure what exactly was done on this latest firmware but stability on my iphone 15 pro and pro max has definitely seen an improvement. In 48 hrs i think i saw twice a disconnect from the wifi to cellular, it’s moving in the right direction. Maybe the next update will see even better results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FW V9.10.4.1 should not fix this issue. Issue should come back after a while.
We already have a fix for connectivity issues on phones, if need please reach out to me. The new firmware which still needs to go through quality assurannce testing. Only message me if you are okay with this.
In the meantime something that can be done on iPhone as well is the following :
Settings --> Cellular -->Cellular Data Options --> Voice & Data ---> 5G Auto to 5G On
5G Auto will allow iPhone to prefer Cellular Data over WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Sorry for late response, I was out for the Holidays. Happy New Year All!!
I have responded privately to those awaiting new firmware.
Please update here in forum if new firmware helps or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Happy to report that i have been testing beta firmware for 4 days now and platform has been rock solid stable, no drops on my iphones 15 pro and pro max. Will report back if i encounter any issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Sorry for those waiting for new firmware. Just responded to all of the messages requesting early access firmware
Best,
Straq
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
