skooter25's avatar
skooter25
The router loses connection to the internet
I have been dealing with this same issue for 2 weeks now and nothing has changed.  My system will be connected to the internet on the "main" network and the "guest" network will lose internet connection, then later in the day it will switch to no internet on "main" and there will be internet on "guest".  No issues with my Google fiber as when these Orbi issues happen I can switch to my Google Wifi network and have no internet connection issues.
  • FURRYe38's avatar
    Does the front LED turn PINK when this happens?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    • skooter25's avatar
      skooter25
      So, I finally got the customer support to connect me to a "Tier 2" support... we are trying a beta firmware right now
      • FURRYe38's avatar
        Good.
        Please give feedback to the question presented as well. Thank you.
      skooter25
      Monoprice Cat 8 between router and orbi.
      Google Fiber 8gb service GFRG300.
      1 satellite
      2700sqft home
      Lose of internet on main happens wired or wireless. Guest is wireless.
      • FURRYe38's avatar
        Is the CAT cable UTP or STP cabling. STP cabling is recommended here.
        30 feet distance between RBR and RBS is recommended as well.
